JerryPittsJr Posted February 3, 2019 Report Share Posted February 3, 2019 I have a Celebrity Broadway Hot Tub that I purchased new in 2016. Two issues I am having. It only seems to run on high speed and it will not turn off resulting in the water to overheat if I don't manually unplug it. I can turn it off, but it automatically turns back on even with the temperature already above the set temperature. Any suggestions as to what the problem might be? I have had to replace the heater and cable that were likely damaged due to the overheating. Quote Link to comment Share on other sites More sharing options...
Okraab Posted April 14, 2019 Report Share Posted April 14, 2019 On 2/3/2019 at 11:07 AM, JerryPittsJr said: I have a Celebrity Broadway Hot Tub that I purchased new in 2016. Two issues I am having. It only seems to run on high speed and it will not turn off resulting in the water to overheat if I don't manually unplug it. I can turn it off, but it automatically turns back on even with the temperature already above the set temperature. Any suggestions as to what the problem might be? I have had to replace the heater and cable that were likely damaged due to the overheating. Quote Link to comment Share on other sites More sharing options...
