2013 Limelight Flair Control Board Replacement
Paul S
That part number should work. You should make sure you use the correct silicone to seal it to the bar top. If you do not use Dow Corning 839 you can damage the electronic components in the control board.  Your local dealer should have both for you, and would be your best source for a service call.
  • 4 weeks later...
I replaced the board but pump 2 is not working. It was before the top board went bad. I noticed the black wire from motor 2 is not connected. Apparently it was working with only the green and white wires connected. Two questions: (1) Can I test pump 2 by plugging all three wires from pump 2 onto the pump 1 pins? (2) Does the new top board need to have the pump 2 black wire plugged in somewhere?
Any suggestions?
