display is flashing ice and then 103
FanmaN
Hi there, I'm new to this sight and after reading some older posts, still couldn't found a solution to my problem.  my Jacuzzi j375 is intermittently going into "ice" mode. when this happens both pumps are on full and its protecting itself like it should, only problem is the tub is at 103. the display toggles back and forth between "ice" and "103". I was working on the two speed pump yesterday replacing a start up capacitor and after that it started. it's very intermittent though. We were getting in yesterday when i noticed the pumps were already on and i saw the "ice" flashing, but after about 10 minutes of use i noticed it was back to normal display, and i hadn't done anything. Today it did it again. I was sitting inside and heard the pumps fire up. I had to reset the breaker to make it stop. I have previously (2 weeks ago) had it staying at 98 when set at 103, and breaker reset "fixed" that. 🙄 Now i'm wondering if both are related and I have an intermittent faulty temp sensor. i had to move aside the harness to the temp sensor to access my capacitor yesterday but never to a point of pulling on it or anything. Any help would be appreciated, Thx
