1988 Grandee heater box
Jimmy11
Remove it from spa,wine corks can be used to plug the lines if spa is not drained,remove the insulation,clean it up best you can, fill with water and loop a hose to both outlets and pressurize smaller drain tube to find the leak,if it is an element gasket,that's pretty easy or you might  have to find a stainless steal welder. I do have a used one if you think you need it.
  • 1 month later...
