Endless pool Insulation
I have an outdoor above ground endless pool which is nearing completion, I am concerned about heat loss. The pool sits on a 20cm fibre reinforced slab and has 15cm of wall cavity insulation and 40 cm of brick all round. The pool is 5M x 2.5M 9000 litres which I would like to keep at 2- to 23 degrees all year round, I have a heat exchanger on my boiler and a 17Kw air heat pump .
My issue is heat loss through the water surface so I need a cost effective lid, I can't find one that will fit and be easy to remove, is there a simple solution?
Rob
  • 3 weeks later...
  • 3 weeks later...
  • 3 months later...
