Robert Cooper Posted October 7, 2018 Report Share Posted October 7, 2018 I have an outdoor above ground endless pool which is nearing completion, I am concerned about heat loss. The pool sits on a 20cm fibre reinforced slab and has 15cm of wall cavity insulation and 40 cm of brick all round. The pool is 5M x 2.5M 9000 litres which I would like to keep at 2- to 23 degrees all year round, I have a heat exchanger on my boiler and a 17Kw air heat pump . My issue is heat loss through the water surface so I need a cost effective lid, I can't find one that will fit and be easy to remove, is there a simple solution? Rob Quote Link to comment Share on other sites More sharing options...
Emma Nathan Posted October 26, 2018 Report Share Posted October 26, 2018 I think DIY is not a good idea now. I suggest you call some pros! Quote Link to comment Share on other sites More sharing options...
Robert Cooper Posted October 26, 2018 Author Report Share Posted October 26, 2018 The want £3K its a rip off and there ar no pros that I can find Quote Link to comment Share on other sites More sharing options...
Robert Cooper Posted November 13, 2018 Author Report Share Posted November 13, 2018 Cool, where do you get Bifold covers from? Quote Link to comment Share on other sites More sharing options...
SamuelMenke Posted February 20, 2019 Report Share Posted February 20, 2019 I think you should consult a professional. Quote Link to comment Share on other sites More sharing options...
Robert Cooper Posted February 20, 2019 Author Report Share Posted February 20, 2019 If only I could find one! Quote Link to comment Share on other sites More sharing options...
