jvietri Posted September 29, 2018 Report Share Posted September 29, 2018 Hello, Looking for a little troubleshooting assistance for my 2010 HotSpring Jetsetter spa. This morning i noticed that my temperature had dropped from 100 to 90 degrees. Both the Ready and Power lights on the control panel are blinking in unison. I have tried resetting the spa numerous times by unplugging it and letting it sit for a few hours, same issue when i plug it in. I have removed the filters, run the pump to see if there was an airlock, but same thing. Filter are TriX and they are spotless so it is not a clogged filter. I have also run water through the grey standpipe to try and remove any air bubbles. My cir pump developed a crack last month and i replaced it at the time and all was working fine. The cir pump is running fine, the lights and the jets work, just no heat. Trying to determine if i need a new heater or another new part related to the heater. Any help or suggestions would be greatly appreciated. thank you so much. jv Quote Link to comment Share on other sites More sharing options...
jvietri Posted September 29, 2018 Author Report Share Posted September 29, 2018 UPDATE: I was reading on this forum that the problem could be with a faulty pressure switch. I jumped the pressure switch on the IC2020 control board and the heater came right on. I guess my question is this. Is this a solution i can use going forward, or do i need to replace the whole heater? I dont think the pressure switch is something I can replace independently. Looks like you can replace the thermistors but not the pressure switch. Is t advisable to use this jumper solution? thx Quote Link to comment Share on other sites More sharing options...
Chichimama Posted April 3, 2022 Report Share Posted April 3, 2022 Did u figure this out . We’re experiencing this same issue Quote Link to comment Share on other sites More sharing options...
