rahmann62 Posted September 26, 2018 Report Share Posted September 26, 2018 We have an older Hot Springs Highligh prob early 90's. We purchased a house with a sunroom/spa room. Has always been inside and is in great shape. We filled it and it has been working great. A couple small leaks but have gotten them taken care of. We have been using the spa for about a month with no problems. Yesterday I noticed the temperature of the water is down. I checked and the red heater reset button is tripped. I reset it, it kicks the circulation pump on and runs for about a minute and then trips the reset button again. You have to wait about an hour and the button will reset but only runs for a minute again and then trips again. Any ideas? Quote Link to comment Share on other sites More sharing options...
mrwrick Posted September 26, 2018 Report Share Posted September 26, 2018 Contact Hot Spring reps for guidance about your model by serial number. Also might try to purge the heater of air. If you had open lines with the leaks it might have accumulated air which can cause heater limit to trip because it heats too high quickly, air heats faster than water. Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted September 27, 2018 Report Share Posted September 27, 2018 Sounds like your heater is getting too warm. Maybe air trapped in the heater or no/low flow from the circulation pump. Quote Link to comment Share on other sites More sharing options...
rahmann62 Posted September 28, 2018 Author Report Share Posted September 28, 2018 Well it looks like I got it figured out for now... knock on wood! Something must have been stuck on the circulation pump. I was messing with the tub and the pump started making a bad rattle noise. So I unhooked the lines to see if there was something stuck in the pump, didn't find anything, put it back together and its working good now. Whatever was lodged must have come loose when I disconnected the water lines. Quote Link to comment Share on other sites More sharing options...
KCooper Posted September 10, 2023 Report Share Posted September 10, 2023 I am having this same issue. How do you bleed the air out of the heater. I am afraid to touch the heater because when it goes out, we are out of the hot tub world. It is too expensive to replace in a 30 yr old tub. It usually happens when I refill the tub and try to heat the water initially. Advice would be appreciated! Quote Link to comment Share on other sites More sharing options...
