dez93 Posted September 25, 2018 Report Share Posted September 25, 2018 Hi all. The bulb on my hot spring jetsetter model J has just blown (at least I hope it's the bulb and not something more costly!). The manual says "The light uses a standard 100 watt outdoor PAR lamp". This is presumably the right replacement but it's $20 for an incandescent; I assume this or this would be acceptable (and cheaper!) LED alternatives? I noticed that Philips also do green red & yellow bulbs; have and of you guys ever installed colours other than blue? Do they look terrible? Cheers! Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted September 27, 2018 Report Share Posted September 27, 2018 Make sure the bulb will fit into the cage for the light, which a PAR should be right. You could try green, red is usually not bright enough, and yellow may look unusual in water. Quote Link to comment Share on other sites More sharing options...
