Anyone tried different bulb colours/colors than blue?
dez93
Hi all. The bulb on my hot spring jetsetter model J has just blown (at least I hope it's the bulb and not something more costly!). The manual says "The light uses a standard 100 watt outdoor PAR lamp". This is presumably the right replacement but it's $20 for an incandescent; I assume this or this would be acceptable (and cheaper!) LED alternatives?
I noticed that Philips also do green red & yellow bulbs; have and of you guys ever installed colours other than blue? Do they look terrible?
Cheers!
Make sure the bulb will fit into the cage for the light, which a PAR should be right.  You could try green, red is usually not bright enough, and yellow may look unusual in water.
