Betamax Posted September 12, 2018 Report Share Posted September 12, 2018 I have a 1986 hot springs classic, and I’m pretty sure it’s designed this way, but the circ pump only runs when the heater is engaged. Is this a problem? Should I rig it to run 24/7? Quote Link to comment Share on other sites More sharing options...
NO1UNO Posted September 12, 2018 Report Share Posted September 12, 2018 If it's running when you want and heating when it's supposed to, I wouldn't jack with it. While I'm not the biggest HS fan around, I will say that their tech support is top notch. So if you're looking for a definitive answer on a unit that old, I'd go straight to the source. Pretty sure they've archived all the manuals for pre 2000 units so a phone call will be in order. Good luck sir. Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted September 12, 2018 Report Share Posted September 12, 2018 Circ pump should run 24/7. Call dealer for service to make it run properly. Quote Link to comment Share on other sites More sharing options...
