Erin Posted August 27, 2018 Report Share Posted August 27, 2018 I have a leak in a tube in my hot tub and I can't figure out what it is. It is in the bottom corner to the right, it is a clear tube and it was attached to a big black flex pipe. It doesn't always leak buy 75% of the time after we have turned on the jets it leaks. It is a hot springs Landmark 2001 model S and it doesn't have an ozanato on it. Quote Link to comment Share on other sites More sharing options...
NO1UNO Posted August 29, 2018 Report Share Posted August 29, 2018 Is it leaking at a fitting where it connects to something or is it leaking in the middle of the tube? Quote Link to comment Share on other sites More sharing options...
Erin Posted August 29, 2018 Author Report Share Posted August 29, 2018 No, this tibe feeds into a black flex pipe that I think is either air intake or exhaust. I can't figure out how to post pics Quote Link to comment Share on other sites More sharing options...
NO1UNO Posted August 29, 2018 Report Share Posted August 29, 2018 I guess what I'm getting at is that it shouldn't matter what its connected to. If it's leaking at a fitting, replumb the fitting. If it's leaking from loose tubing, cut it and splice in a barbed connector with clamps. If you're just wanting to know what the line is, it's been a while since I've been in front of an old landmark but small clear tubing is typically an ozone line. I know you say your tub doesn't have ozone but it might have at one point. Download some pics onto your computer and use the "choose files" link in the lower left portion of the reply screen. We'll figure it out... maybe. Quote Link to comment Share on other sites More sharing options...
