Aaronius Posted August 26, 2018 Report Share Posted August 26, 2018 Greetings. I have Sundance Majesta that needs a replacement pump. The rubber mounts have torn and need replaced. They are just like these, which I've purchased 4 replacements as well. The threaded metal "bolt" isn't one piece. There is a top and bottom "bolt" with the thick rubber bushing between them. But, I can't seem to get the 4 old "stems" out of the wood floor (the rubber bushing and top bolt have broken off and been removed). Any suggestions on how to remove these old stems? Can't get enough "bite" from channel locks. I assume they just unscrew from another threaded metal piece pressed into the bottom of the flooring hole (or something like that). Or, can I cut a new piece of pressed board to put over the old area, screw it to the floor and mount the pump on that? Looking for advice. Thanks! Quote Link to comment Share on other sites More sharing options...
NO1UNO Posted August 29, 2018 Report Share Posted August 29, 2018 Cut them off, patch in the new piece of treated pressed board and mount that sucker. Getting those things out can be a bear. Good luck. Quote Link to comment Share on other sites More sharing options...
Aaronius Posted August 30, 2018 Author Report Share Posted August 30, 2018 Thanks! Quote Link to comment Share on other sites More sharing options...
