sdfallon11@gmail.com Posted August 20, 2018 Report Share Posted August 20, 2018 Plugged in. Heat indicator on. No jets. 15 secs or so pops breaker. Keep trying other outlets. Breakers popping. Is it only a mattet if a dedicated breaker or should i be concerned about motor? I have no way to test without installing new breaker and outlet. Quote Link to comment Share on other sites More sharing options...
wondertub Posted August 26, 2018 Report Share Posted August 26, 2018 I don't think there's really a difference between a dedicated one or not if you have everything else shut off when you test the tub. Generally people have more appliances hooked up than they can turn on all at the same time, and it works out that way. Quote Link to comment Share on other sites More sharing options...
