Ophelia Posted August 18, 2018 Report Share Posted August 18, 2018 I had a burnt up circuit card and a failed motor. I have replaced both on a single pump system. When I plug in the disconnect, the system normally starts up after about 10 seconds. This is not happening. However, it will start if I press the jets button on the control panel and it will go to high speed operation. It then shuts down after 2 minutes of run time. The system will not run again until it is completely powered down at the disconnect. I believe that I may have mistakenly connected the wires under the power input ADAR on the circuit board. There were no instructions with the circuit board. The circuit board has 3 male spade connectors. I connected to the top 2. Would this connection create my symptoms? Which spade connectors should I be using? Thanks much! Quote Link to comment Share on other sites More sharing options...
