Nanskier 0 Posted August 11, 2018 Report Share Posted August 11, 2018 We have a 30,000 gal. Pool it was green we got some citric acid and the bag 50lbs was put in accidentally. It cleared the pool, but afraid of how much went into the pool. This is overdosed big time! What do we do now???o Quote Link to post Share on other sites
waterbear 102 Posted September 29, 2018 Report Share Posted September 29, 2018 Citric acid is used to remove staining from pool at a rate of about 1 lb. per 10k gallons. Green pool is usually from algae and chlorine is what you would use, not citric acid. . Citric acid will also destroy any chlorine in your pool and make it very hard to maintain a chlorine level untill all the citric acid is oxidized. Citric acid will also drop your pH and TA. Can't really help you without more info. Full set of test results (not done with strips), pool surface (plaster, fiberglass, vinyl), etc. Quote Link to post Share on other sites
vanducote52 0 Posted May 24, 2019 Report Share Posted May 24, 2019 Good info. This is my situation. I used about 4 lbs. of citric acid in a 20k salt pool. It took the stains out but now I can maintain chlorine. One question. How long does it usually take for citric acid to be eliminated from pool water. All my level are good except chlorine. Also my pool is cloudy. Quote Link to post Share on other sites
vanducote52 0 Posted May 24, 2019 Report Share Posted May 24, 2019 Sorry, I can't maintain chlorine. Quote Link to post Share on other sites
Liam569 0 Posted May 28, 2019 Report Share Posted May 28, 2019 It will take time, but it should disappear from your pool, then you can change the mixture. Quote Link to post Share on other sites
Superlopez 0 Posted October 9, 2019 Report Share Posted October 9, 2019 I have exactly the same problem. Someone told me it was good for removing copper stains. I added 10lbs in my 15k gallons pool and now it's cloudy and unbalanced. Did you find a solution? Quote Link to post Share on other sites
Jason B 0 Posted May 3, 2020 Report Share Posted May 3, 2020 Great site!!! I’ve posted it on some pool forums I’m on. https://www.medallionenergy.com/blog/pool-stain-removal-guide/ Question, in the past I’ve gotten vitamin C/abscobic acid and it removes metal stands for my steps and parts of the liner. It works great, now that vitamin C powder has tripled in price and I see citric acid powder for super low prices. Will this do the exact same thing? And does it work as good as the vitamin C? Quote Link to post Share on other sites
