greenacres Posted August 7, 2018 Report Share Posted August 7, 2018 I have a 2000 hot spring grandee with a major leak coming from #2 pump plumbing. After filling the hot tub I could hear water dripping. the tub is on a raised deck so I can see underneath the tub. It was dripping pretty bad, when I turned # 1pump on the leak stayed the same, turned the pump off. Turned #2 pump on and it was pouring out from underneath really bad. Does anyone have a plumbing diagram for this Hot Spring model showing the hoses and manifolds. Thanks Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted August 7, 2018 Report Share Posted August 7, 2018 If it is just with jet pump 2, the leak could be coming from the pump union. Your local dealer should be able to help get you back up again. Quote Link to comment Share on other sites More sharing options...
