Need help with Bromine start
mkinsocal
Hi All -- sorry, I know this has been discussed numerous times, but I just feel like something's not going right.  We have an 800 gallon in-ground Jacuzzi. The salt-water cell finally gave out, so rather than spend another $500+ on a new one, I figured this would be a good time to try out bromine.  Followed the three step plan laid out by Waterbear by getting pH, etc in balance, adding 4 oz bromine startup, followed by 20 ounces of bleach, then added a floater with 3 one-inch bromine-chlorine tabs and the floater is about 25% open. The filter runs about 8 hours a day.  pH has been kept in the 7.4-7.8 range. We have neither heated, nor used, the Jacuzzi since the generator went out last week.
After the initial bromine / shock, the Br was about 5 (use Taylor DPD kit) checked 1 hour after bleach.  Checked again on day 2 and test water did not turn pink after adding 2 scoops of powder. At that point, I realized that the bleach was maybe getting old (have had it over 1 year, and it seemed to be more clear than yellow in appearance). Went to store and bought new bottle of concentrated bleach (8.25%) and added another shock, but cut it down proportionally by volume since it was stronger.  This time, Br was 6.25 after 1 hour.  Checked the following day (today) and it's back to nothing.  Had to rush to work, but will do another shock when I get home.
So at this point, I'm thinking that it's just getting chewed up by some invisible organics since there was a period of a few days where the salt-water generator was probably off and on. The water has always been crystal clear, and still is, but I know that doesn't necessarily mean it's fully sanitized.
My questions are: 1) At what point do I stop adding chlorine and question whether I have enough bromine?  2) How do I know when I should add more bromine tabs or open the floater more?  3) How do I know what I'm measuring with the Taylor kit is bromine, and not just the chlorine that I dumped in (ie, how would I know if I'm completely out of bromine reserve?);   I'm not sure if this means anything, but for the first two days, the water smelled strongly of chemicals (even before dumping in bleach) -- smelled like a cheap hotel hot tub (not that I know what that smells like -- ha!).  Now the water does not smell.
Of course, there's never a good time for this to happen, but we're hosting a b-day party Sunday, so would love to sort this out so that the Jacuzzi can be used. Don't want to send the kids home with a hot-tub rash as their party favor.  Anyway, thanks in advance for any advice.
  • 1 month later...
Hi there - saw your post and wondered if you were able to find an answer! I am having the same problem on startup and haven't been on the forum for quite some time but figured I'd see what was out there! I sent a message to Waterbear, who has been an amazing resource for such issues and I hope I hear back soon. I will message you if I do, if that's okay! Meantime, sure hope you have been able to use your spa.
