mkinsocal Posted July 18, 2018 Report Share Posted July 18, 2018 Hi All -- sorry, I know this has been discussed numerous times, but I just feel like something's not going right. We have an 800 gallon in-ground Jacuzzi. The salt-water cell finally gave out, so rather than spend another $500+ on a new one, I figured this would be a good time to try out bromine. Followed the three step plan laid out by Waterbear by getting pH, etc in balance, adding 4 oz bromine startup, followed by 20 ounces of bleach, then added a floater with 3 one-inch bromine-chlorine tabs and the floater is about 25% open. The filter runs about 8 hours a day. pH has been kept in the 7.4-7.8 range. We have neither heated, nor used, the Jacuzzi since the generator went out last week. After the initial bromine / shock, the Br was about 5 (use Taylor DPD kit) checked 1 hour after bleach. Checked again on day 2 and test water did not turn pink after adding 2 scoops of powder. At that point, I realized that the bleach was maybe getting old (have had it over 1 year, and it seemed to be more clear than yellow in appearance). Went to store and bought new bottle of concentrated bleach (8.25%) and added another shock, but cut it down proportionally by volume since it was stronger. This time, Br was 6.25 after 1 hour. Checked the following day (today) and it's back to nothing. Had to rush to work, but will do another shock when I get home. So at this point, I'm thinking that it's just getting chewed up by some invisible organics since there was a period of a few days where the salt-water generator was probably off and on. The water has always been crystal clear, and still is, but I know that doesn't necessarily mean it's fully sanitized. My questions are: 1) At what point do I stop adding chlorine and question whether I have enough bromine? 2) How do I know when I should add more bromine tabs or open the floater more? 3) How do I know what I'm measuring with the Taylor kit is bromine, and not just the chlorine that I dumped in (ie, how would I know if I'm completely out of bromine reserve?); I'm not sure if this means anything, but for the first two days, the water smelled strongly of chemicals (even before dumping in bleach) -- smelled like a cheap hotel hot tub (not that I know what that smells like -- ha!). Now the water does not smell. Of course, there's never a good time for this to happen, but we're hosting a b-day party Sunday, so would love to sort this out so that the Jacuzzi can be used. Don't want to send the kids home with a hot-tub rash as their party favor. Anyway, thanks in advance for any advice. Quote Link to comment Share on other sites More sharing options...
klhPerry Posted August 25, 2018 Report Share Posted August 25, 2018 Hi there - saw your post and wondered if you were able to find an answer! I am having the same problem on startup and haven't been on the forum for quite some time but figured I'd see what was out there! I sent a message to Waterbear, who has been an amazing resource for such issues and I hope I hear back soon. I will message you if I do, if that's okay! Meantime, sure hope you have been able to use your spa. Quote Link to comment Share on other sites More sharing options...
