Rob1973
Hot Springs problems ! Please help
Hi all.
I have a Hot Springs.Grandee, following a house move its been sat on the drive, empty for 24 months, renovations finished so finally got into its new location.
Filled as had previously, turned on, circulation pump started, lots of bubbles, within 60seconds both green ready light and blue power light start flashing.
No controls work, thought maybe block filter, removed and reset, same issue. Thought made air lock, hose down 'grey' inlet, reset, same issue.
Remove sensors from heater, plenty of water flowing, reset, same, both lights flashing.
Any ideas?
Thanks in advance
Rob
Share this post
Link to post
Update: discounted power to heater, power light has stopped flashing, no ready light (not lit or flashing) controls do no operate.
Assuming heater had failed, however concerned can't get controls / jets to work?
Share this post
Link to post
Controls are run off 120v
Here is a video I did explaining how to test your control panel and jets on a Hot Springs.  My understanding is that the heater element is ran using the 240v.
Share this post
Link to post
Thanks, when I turn the power on, circulation pump starts fine, but controls won't let me select any option, then the screen goes to sleep???
I am going to drain and take the heater out and get it tested, I will also check circulation pump and any blockages.
Share this post
Link to post
UPDATE: took time to get everything ready for a refill, lots of brittle plastic around heater, but plenty of plastic weld and sealant finally got a seal. As I refilled I made sure I sure directed the hose into every nozzle, jet etc to make sure no air locks. Checked all connections, turned on and its all come to life, now just need to wait to see it heater works, fingers crossed (did check resistance and seemed ok)
Share this post
Link to post
