poolcare novice Posted June 14, 2018 Report Share Posted June 14, 2018 I have an old Polaris 180 which didn't seem to picking up as much of the leaves, etc. at the bottom of the pool as it usually did. For the first time I followed the backwashing instructions as best I could and I see a tremendous improvement. The manual only says: "...occasionally flush out the Polaris..." so I would like to know how often I should backwash it. Also, exactly what is the backwashing process doing since only water should be traveling through the interior of the unit? Thank you. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted June 15, 2018 Report Share Posted June 15, 2018 The finger screen at the wall fitting, or inline, should be catching all the debris, and a "back washing" should not be necessary. But that is in a perfect world. Best answer is when ever you notice that the unit is not moving as quickly it used to, or picking up as well as it used to, that would be the time to back wash. Quote Link to comment Share on other sites More sharing options...
poolcare novice Posted June 16, 2018 Author Report Share Posted June 16, 2018 On 6/15/2018 at 7:56 AM, Pool Clown said: The finger screen at the wall fitting, or inline, should be catching all the debris, and a "back washing" should not be necessary. But that is in a perfect world. Best answer is when ever you notice that the unit is not moving as quickly it used to, or picking up as well as it used to, that would be the time to back wash. Thank you. The inline screen stays very clean but I do clean it out every time I backwash or have the filter cleaned anyway. I am not mechanically inclined so as I study the Polaris I cannot see how anything could clog the interior and be removed by backwashing but it certainly made a difference so I won't worry about an explanation. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 27, 2018 Report Share Posted July 27, 2018 Water jets are used for two important functions of the Polaris. To drive it, and to vacuum up debris. If you get debris in the jets they wont give the "thrust" need to either drive the unit, or vacuum debris into the bag. Quote Link to comment Share on other sites More sharing options...
