JohnB Posted May 25, 2018 Report Share Posted May 25, 2018 I have a pretty old (1998) California Cooperage tub, Model 105. Replaced the pump and heater last year and all was working perfect, up until a couple weeks ago. The filter cycle, which normally runs for 3 hours every 12 hours, has been cycling ON and OFF constantly during that 3 hour period... For example, during the 3 hour filter cycle, the pump (and sometimes the heater) will run for only about 2 minutes, then will shut off for about 20 minutes. This happens constantly throughout the 3 hour period. I initially though it was the pump overheating, but it does not get hot and there are no error codes. Also, if I manually turn on the pump, high or low, with the control panel, it runs totally fine for as long as I want it to. It has no problem maintaining the set temp throughout the day either. Could it be a circuit board issue? I believe its the original board still...Thanks in advance! Quote Link to comment Share on other sites More sharing options...
