Gratenaf Posted May 24, 2018 Report Share Posted May 24, 2018 I have an RS6 controller and power panel. All pumps stopped working. The motherboard lit up and buttons were lighting up when pressed. The inside controller works just fine. I opened up the Powerpanel and saw that the wire was fried and separated from the relay. I replaced the main pump relay ( upper left ). When I flipped the pump breaker, the filter pump turned on, but the buttons did nothing to affect the pump. Oddly, the inside spa button to turn on the spa actually turned on the spa. Outside spa button did nothing. Inside controller will tell me if the outside is in service mode. So there is communication going both ways. I replaced the remaining 5 relays. Still having the same issue. Pump turns on/off only at breaker box. Any ideas? Nate Additionally I have two other pumps for the cleaner and waterfall. They have not turned on whatsoever. Quote Link to comment Share on other sites More sharing options...
