Sign in to follow this
Coralie
Cleaning swimming pool
I like swimming very much. At first, I was scared of swimming. When I was a kid, I drowned in water while playing on the beach with my family. Since then, I was scared of swimming and I quit swimming forever. My husband is a good swimmer. He loves swimming very much. He helped me overcome my fear of swimming. He taught me swimming and I started to love swimming. When I was pregnant with my first child, my doctor suggested me swimming exercises as it is good for maintaining the health of a pregnant lady. My husband called a swimming pool construction in Massachusetts and they built a swimming pool in the backyard of my house. I used to swim in the pool during pregnancy and even after delivery. But nowadays, I can't swim properly since I have got leg cramps. Since we are not using the pool nowadays, the pool is not maintained well. Can you suggest some tips to clean the pool?
Share this post
Link to post
I too love swimming. We spend our leisure time in the pool. My husband and kids are good swimmers. Our pool constructors were from Calgary. Last day I had faced some problems with the water supply of our pool. I had called up plumbing repair services in Calgary. But during those days, I was not able to use the pool.
I can help you. Here are some tips for cleaning our pool. Proper skimming and brushing is the first step. Skim the pool's surface with a leaf skimmer. It is better to do it every day to avoid contamination. Connect the skimmer to the telescopic pole to start. By using the net, we can take off the debris. After clearing off the debris with the help of the brush, clean the sides of the pool. Don't forget to clean the pool ladder. To clean the pool floor use a pool vacuum. After cleaning, check the pH of water. We can buy the tester from the market.
Share this post
Link to post
If you have a bit of money to spend, consider buying a robot vacuum that will clean the bottom of the pool for you. it will be useful for weekly maintenance of the pool.
Share this post
Link to post
vacuuming it will help get rid of it. shocking it will raise your chlroine levels. I know you guys probably know this, but some wont, if your alkinity is low in your pool, add baking powder instead of buying alkinity raiser. its way cheaper. also, when trying to get levels equal, when you raise your alkinity, your PH levels will go up.
also if you cyanuric acid levels are 0 in your pool water, your pool wont hold chlorine in the pool. you need to add stabilizer then, and if your pool water temperature is too low, it wont hold stabilizer or chlorine.
Share this post
Link to post
I love swimming too. When I was swimming in the pool, sometimes I noticed that water come into my ears and was getting infections due to water entering my ears. I was looking for some ears protections so that when I swim in the pool need to keep my ears safe from water. Then I got the solution to bought a custom swimming earplugs. Now I am enjoying my swimming for getting the nice earplugs.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
