green bubbles
azarett
New tub owner ( So I stink at reading chemical tests ?) But I'm trying.
About 2 weeks ago, the water got cloudy. Hard to be sure due to color of tub, but It looked slightly green, so I thought 'algicide'
So I did. The algicide only had dosing for 10,000 pools. ( although it said pool & spa on the package)
 I thought it worked because the next day, water seemed clear, and the top had a lot of green matter on the surface. I assumed the green was dead alge .
The water has been clear since then, but the angicide said to add small amount each week. Every time I add, I get green foam when the pump cycles.
It the green being caused by too much algicide ? or is it just green because I have not killed off ALL the alge ?
The pics is from this morning
Thanks.
