SparkysPool Posted April 4, 2018 Report Share Posted April 4, 2018 The HTH test kit and many other sources say the only way to lower the CYA is to drain some water. My Pool is vinyl 5000 gal, soft water, Cal Hardness 150, DOES NOT LEAK, water 6 years old salt has gone from 3000 to 5400 ppm Why do I have to put More Cyanuric acid in Every start up and During the year to keep it around 40. By the way the pool is in great shape no problems with the water, just don't understand the lowering of the Cya. Sparky Found good answer here - - - >> http://www.poolforum.com/pf2/showthread.php/5762-Does-winter-(midwest)-impact-CYA-levels Quote Link to comment Share on other sites More sharing options...
