John Taylor Posted March 10, 2018 Report Share Posted March 10, 2018 Installed new recirculating pump now pumps runs all the time any thoughts. Quote Link to comment Share on other sites More sharing options...
castletonia Posted March 11, 2018 Report Share Posted March 11, 2018 The circulation pump is supposed to run 24/7. Quote Link to comment Share on other sites More sharing options...
JACKVJR Posted March 11, 2018 Report Share Posted March 11, 2018 X2 - if the heater circulating pump is not running, it's dead or there's a serious control issue. However, you say "pumps". The Kauai only has two and the jet pump is NOT supposed to run all the time. jack vines Quote Link to comment Share on other sites More sharing options...
John Taylor Posted March 12, 2018 Author Report Share Posted March 12, 2018 The small pump that pumps when the heater cuts on after you cut the temperature the small pumps runs all the then you get 4 dashes across the screen Thank John Quote Link to comment Share on other sites More sharing options...
John Taylor Posted March 12, 2018 Author Report Share Posted March 12, 2018 Thank you didn't realize that pump ran continuously that helps alot. Thank You John Quote Link to comment Share on other sites More sharing options...
John Taylor Posted March 12, 2018 Author Report Share Posted March 12, 2018 Thank you for taking the time to answer these questions. Thank You John Quote Link to comment Share on other sites More sharing options...
