rrs1179 Posted March 10, 2018 Report Share Posted March 10, 2018 So, hoping someone can answer my question. Thanks in advance if you can. I had a major leak on my Down East hottub. Tracked it down to, what I believe is called, the bleeder plug. The O-ring looks to be shot. The problem I am having is that I can't get it to screw back into the fluid end. I have not replaced the o-ring and don't know if I may have a bigger problem. It somewhat screws in when I take the o-ring completely off. I hope this makes sense and it's a common problem. I have pictures of what I am calling the bleeder plug. https://ibb.co/jPdjxn https://ibb.co/dXEPxn Quote Link to comment Share on other sites More sharing options...
Cusser Posted March 10, 2018 Report Share Posted March 10, 2018 Looks like the threads are bad on your plug, get a new plug. Since there's an O-ring, it's NOT tapered pipe threads, the O-ring is the seal, and you shouldn't need to overtighten either. I'd contact the manufacturer to get a new plug, or at least find out the correct thread size. I doubt that you'd need to tap new/larger thread size. A thread chaser of the correct size might help. In some ways this looks similar to bad threads of an oil pan drain plug on a vehicle. There are rubber expansion plugs available for those that might work for you if nothing else does. Quote Link to comment Share on other sites More sharing options...
fboyles Posted March 10, 2018 Report Share Posted March 10, 2018 I have very little experience with tubs but not in hardware. I have ran into similar problems threading dry plastics into dry threads. If they threads on both ends look good I would want to add some sort of lube to the threads and the O ring to get a good seal. It would take much lube but I would want to find a produce that is safe to use in tubs. To run with the oil pan analogy you would do the same. Just my 2 cents. Quote Link to comment Share on other sites More sharing options...
