TroyNYRoy Posted January 25, 2018 Report Share Posted January 25, 2018 I have a master spa HL 630 I really want to be able to control the air blower Living in the Northeast it's not beneficial to run the blower during the cold winter months. I'm not opening the air blower valves into the water, but the blower is still running...I want to be able to turn it off...MY perfect solution would be to turn the blower on with the Aux switch on my control panel....I don''t see where on the control panel mother board a line going out for the blower motor........does anyone know where the blower motor is getting it's power from...this would help...if you can direct me in plugging in the blower motor to the aux lines on the control panels...this would be what I'm looking for. Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted January 26, 2018 Report Share Posted January 26, 2018 Just disconnect the blower from the circuit board for the winter. The inside of the spa pack has a wiring diagram that will show you which connector is for the blower. The AUX button may be a solution, but make sure the circuitry is set for the proper voltage. They used both 120V and 240V blowers in spas, and you can burn out a 120V blower pretty quickly connecting it to a 240 source. Dave Quote Link to comment Share on other sites More sharing options...
TroyNYRoy Posted January 26, 2018 Author Report Share Posted January 26, 2018 Yes.....I searched the circuit board for just such a connection....there isn't one for the blower....I found pump, led, ion, heater, But nothing labeled for blower.... Quote Link to comment Share on other sites More sharing options...
TroyNYRoy Posted January 26, 2018 Author Report Share Posted January 26, 2018 Not sure that I can use the Aux plug on the circuit board, as it is a much smaller and different female plug then anything else on the panel As if it's designed for something that would require only small power.... Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted January 26, 2018 Report Share Posted January 26, 2018 Sounds like your only option is to disconnect the blower for the winter . . . Dave Quote Link to comment Share on other sites More sharing options...
TroyNYRoy Posted January 26, 2018 Author Report Share Posted January 26, 2018 Yes.......now to find it......there's so much foam insulation and aluminum wrap under the spa.......all I can do is hear it......can't see it....Thinking it's hidden behind the control panel circuit board....that's where I hear it anyway.....I know it has to have a elec wire running to it.......I will wait for warmer weather...then craw around under there Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted January 26, 2018 Report Share Posted January 26, 2018 I meant disconnect the blower from the circuit board. There's no wiring diagram on the pack showing which jack is for the blower? If you include a picture of the spa pack, I'll try to look it up for you. Dave Quote Link to comment Share on other sites More sharing options...
TroyNYRoy Posted January 27, 2018 Author Report Share Posted January 27, 2018 let me see what the weather is the next few days.....I will get you a picture of my circuit board Quote Link to comment Share on other sites More sharing options...
