SirxRaptor Posted January 15, 2018 Report Share Posted January 15, 2018 I'm baffled at how this jet body is held in place. I don't see a nut. Is it pure silicone sealant? Should I just pry/twist it off? You can see it has a broken nipple - I've got a replacement for the jet body. Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted January 16, 2018 Report Share Posted January 16, 2018 It probably has a second piece that screws in from the front side. On the "pool" side, remove the jet internals and look for either two, three or four notches that you would grab with a special tool to turn the body. There are many different "special tools" so you'll probably need a little ingenuity. If you're going to throw out the old jet, you can just cut it out, but make sure you know how you're going to install the new one first. Installation example: www.balboawatergroup.com/getdoc.cfm?id=1748 Dave Quote Link to comment Share on other sites More sharing options...
SirxRaptor Posted January 20, 2018 Author Report Share Posted January 20, 2018 Thanks. Turns out I was off. No threads OR silicone. The jet body was just a tight fit into the rubber gasket set in the spa wall. Some pushing, a bit of a turn, and it slowly came out. Quote Link to comment Share on other sites More sharing options...
