How do i get jet bodies off shell?
SirxRaptor
It probably has a second piece that screws in from the front side.  On the "pool" side,  remove the jet internals and look for either two, three or four notches that you would grab with a special tool to turn the body.
There are many different "special tools" so you'll probably need a little ingenuity.  If you're going to throw out the old jet, you can just cut it out, but make sure you know how you're going to install the new one first.
Installation example: www.balboawatergroup.com/getdoc.cfm?id=1748
Dave
