Pumps run slow and overheat
Martin5k
Sounds like the voltage to the pumps could be wrong.  Need to check jumpers and instructions and see if the new Pack has different setups for 110v or 220v.  Sometimes you need to move wires within the pack.  Usually that situation means that the pumps are 220v and only getting 110v, but check first to see what voltage the pumps are supposed to be and double check the instructions.
*****I just looked at Balboa 501z wiring diagram and it looks like only the heater or blower can be 220v....so if you have 220v pumps I don't think you can use that Pack unless the pumps are convertible back to 110v.
Read the instructions and check voltages to confirm....
