Mike Miller Posted January 10, 2018 Report Share Posted January 10, 2018 All- tldr; Where does an air bleed line go to? Two links, one is in the filter area. Do I need the other? So I broke the 1/4" air bleed trying to restart my 2001 vanguard yesterday. Went to the hardware store, grabbed the parts and some epoxy and rebuilt it. While trying to maneuver the 1/4" air bleed line into place a t-tap broke off on the other end. One end goes into the filter area and the other snakes around the side where I have to remove the covering to get to it (I already started and decided to stop until I have better advice, it looks like a mess to tear that foam away for something I don't even understand. Where does it go? Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted January 10, 2018 Report Share Posted January 10, 2018 You can plug most bleed lines without affecting the operation of the tub. For the most part, the bleed lines prevent air-locks when filling empty pipes and pumps. Dave Quote Link to comment Share on other sites More sharing options...
