Clyde J. Whitmire 0 Posted December 12, 2017 Report Share Posted December 12, 2017 Eliminate drain suction hazards: Inspect pools daily to ensure drain covers are in good condition and securely attached. Do not operate shallow (less than 18 inches) pools with a single main drain suction outlet. Post a sign: “WARNING — To prevent serious injury, do not allow children in swimming pool if drain cover is broken or missing.” In the event of a fecal accident: Instruct pool users to exit the pool; close the pool (24-hour minimum closure) and remove as much fecal material as possible from the pool. Vacuum the pool and direct waste to a sewer system and not through pool filtration system (disinfect vacuum before reuse). Raise free chlorine residual to 20.0 ppm with pH 7.2 – 7.5 and maintain overnight. Operate filtration system for 3 or 4 turnovers, then backwash. If spa, hot tub, or wading pool is contaminated, drain the pool at this point. Disinfect the filter tank and media with a 20:1 solution of sodium hypochlorite; (alternative: for diatomaceous earth or cartridge filters, replace media or cartridge element). Restart filtration system and neutralize any excessively high residual chlorine with sodium thiosulfate or allow to return to 5 ppm free chlorine. Balance pool water and reopen the pool. Quote Link to post Share on other sites
Alessia Hayden 0 Posted January 30, 2018 Report Share Posted January 30, 2018 Thanks for giving these tips to pools. I have two younger kids I will definitely take care for it. Quote Link to post Share on other sites
Piccirillo 0 Posted May 9, 2018 Report Share Posted May 9, 2018 Oh it was an informative session. Thank you Quote Link to post Share on other sites
MarianGuzman 0 Posted October 26, 2018 Report Share Posted October 26, 2018 Swimming pools are a fun and relaxing place to spend hot summer days. A swimming pool can be a very dangerous place for younger children. So, make sure to fence your pool, especially if your pool is in the yard. You should also use good pool cover which is one of the best things you can do to keep environmental contaminants from entering the water. Make sure to vacuum your pool once a week on average. Use Algaecides which is used for killing of the growth of algae. If you want to eliminate insects or ants completely, then you should hire a pest control Nassau County services. Also use some good quality chemicals that will give you peace of mind that your water clean and safe. Quote Link to post Share on other sites
johnxd 0 Posted December 3, 2018 Report Share Posted December 3, 2018 Thank you! very useful Quote Link to post Share on other sites
LarryArcher 0 Posted May 2, 2019 Report Share Posted May 2, 2019 Thanks for sharing the tips! Quote Link to post Share on other sites
wcoast 0 Posted June 3, 2019 Report Share Posted June 3, 2019 These tips are very useful, thanks for sharing! Quote Link to post Share on other sites
Marcohall 0 Posted July 1, 2019 Report Share Posted July 1, 2019 I think it very informative tips, whoever love to spend time in pool should surely keep this tips in mind. Quote Link to post Share on other sites
intecamerica 0 Posted February 10, 2020 Report Share Posted February 10, 2020 Keep you pools free from chlorine. There are many healthier options available in market for keeping your pools and spas free from chlorine. Quote Link to post Share on other sites
ArthurHolo 1 Posted August 25, 2020 Report Share Posted August 25, 2020 Thanks for your tips. I can add two more: - you can use tennis ball to absorb oils left in the water (lotions, hair products, natural skin oils) - regular baking soda might work as sodium bicarbonate Quote Link to post Share on other sites
Monroy32 0 Posted February 13 Report Share Posted February 13 Thanks for the advice Quote Link to post Share on other sites
