Bleach and Dichlor question
Icebrrg
I don't see why not. Depending on what is in the wipes besides bleach, however, you may be introducing a small amount of soap or other chemicals into the tub water as it contacts those areas when you get into the tub. The chlorine should oxidize the other substances, but it may increase your chlorine demand a little.
Please learn about the use of dichlor if you haven't already studied it. You can follow the dichlor then bleach method sticky post at the top of this forum.
