ben45678
Can't get pH and Alkalinity balanced
I'm having trouble getting pH and alkalinity balanced. Right now alkalinity is ok (80) and pH is high (8.4). If I add pH down, both will go down. If I add alkalinity increaser or baking soda, both go up. According to some websites, alkalinity increaser should raise alkalinity without affecting pH, but that's not what I'm seeing. Any tips? Thanks.
Share this post
Link to post
Get a Free Hot Tub Quote
I was having a issue balancing out my chemicals as well. We drained and refilled and I still was fighting it. I noticed my water hardness was low, once I brought the hardness level to normal I was able to get the other chemicals balanced and keep them there.
Share this post
Link to post
Have hard water here; still having trouble getting ph and alkalinity low enough. Am I correct that too-high-levels of alkalinity and ph interfere with the chlorine doing its job? Because chlorine level is fine...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
