Fritoman26 Posted November 6, 2017 Report Share Posted November 6, 2017 I have a balboa TP600 everything functions as it should except for the 2spd on jet/pump1. It was running on high for heat and filtration mode and wouldn't switch to low. I switched black and red wire position on back of motor now it runs in low but won't switch to high. When the jet button is pushed a second time it simply turns off. I believe since when manually switching the wires the pump motor runs in high or low that rules out the motor. I assume it is in a relay or circuit board or something in controller but don't know where to start. Any info would be appreciated. Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted November 8, 2017 Report Share Posted November 8, 2017 Check the circuit board where the red and black wires are attached. Anything seem out of the ordinary? Dave Quote Link to comment Share on other sites More sharing options...
