kvnbdvs Posted November 6, 2017 Report Share Posted November 6, 2017 I purchased a used 1993 Coleman Hot Tub. I have been using it the past few years. I was getting a "FLO" error message from time to time, but it didn't seem to affect the performance. I was also getting an "ILOC" error once a week or so. It would just be shut down, but as soon as I hit a button or two it would fire back up. I replaced the temp sensor as well as the pressure sensor as I noticed that the wire had broke and had a poor repair job. I just filled it up for the winter and turned it on. It warms up to mid-90s and then an ILOC shows up. I wait several minutes, hit a button on the topside it fires up only to do the same thing... one time it blew the breaker too. I have never had a "SN1" or "SN3" error code, but in the past had seen "OH" a time or two. I haven't touched the heating element, but am wandering if it is damaged. Any help would be appreciated Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted November 9, 2017 Report Share Posted November 9, 2017 iloc usually means there is a magnetic switch on an access door that's open. Putting a magnet on the switch while you work on the spa will usually take care of it. Or, it means the circuit board THINKS there's a open door. If there's no open door, chances are your 24 year old circuit board is not going to make it 25. Dave Quote Link to comment Share on other sites More sharing options...
