schutjer Posted November 1, 2017 Report Share Posted November 1, 2017 I have an older spa in a house I bought. The drain requires that a square handle be lifted to open the pipe to drain. It's kind of a T on top of the drain pipe opening. it is a 1990 Hot Springs sovereign if that helps. I had to drain it with a pump but for cleaning it would be great to get that open. Any tricks or techniques that I am missing? I had a spa repair guy here to help drain it and generally check it out and he said just use the pump which I thought was fine but after he left, I realized it would be nice to be able to open that. The tub is in a house and surrounded by a deck so it is a total pain to get down there to do anything (thus the pump recommendation made total sense). Anyway, if anyone has some advice on how to get this sucker open, that would be cool. Thanks. Quote Link to comment Share on other sites More sharing options...
danthespaman316 Posted November 1, 2017 Report Share Posted November 1, 2017 Sounds like a gate/slice valve. Usually they have a quarter turn locking mechanism where the handle meets the collar. If it still won't open after you turn it counter clockwise, you probably have calcium or other buildup that is seizing the gate. You can try to muscle it or you can cut it out and install a new unit, they run about $20 online. Honestly, I'd use the pump and not mess with the valve. Quote Link to comment Share on other sites More sharing options...
schutjer Posted November 1, 2017 Author Report Share Posted November 1, 2017 Thanks, that is exactly it. I'll try one more time and forget about it. I just thought there was a trick I was not seeing, although the repair guy would have known it. Quote Link to comment Share on other sites More sharing options...
