paalwille
Hotspring Moto massage fault - no air
I have a 2012 Hotspring Sovereign. My double Moto massage jets has stopped going up and down, and I have narrowed the problem down to the air flow in the moto massage compartment. No air comes out of the nozzle in the Moto Massage compartment.
I have already gone through the following steps:
-Changed the Moto Massage jets ( vertebrae tubes)
-Changed the air hose with manifold
- Turned all control valves in different directions
-Cleaned filters (Tri-X)
- Run the jets with filters off for a couple of minutes
-Checked the air inlet in the service compartment
All other jets works fine and are stable
Any suggestions from you??
Paal
Share this post
Link to post
I do recommend checking out the air control valve to that seat. It's likely that you have a misaligned piston in the valve or an obstruction that is preventing air pressure from driving the jet up and down.
Share this post
Link to post
Thank you for that. Will I get to the piston by dismantling the valve from the top..? Would appreciate it if you could explain closer how I get "under the hood"
/Paal
*EDIT*
Found a How-To online. Will try tomorrow. :)
Share this post
Link to post
Hi again. I have checked the valve,and compared to the valve next to it,it looks good. When valve is removed,there is no airflow in the "valve hole" no matter what position the Smart Lever is in.
Any other tips?
Share this post
Link to post
Hi, I was wondering of you ever found an answer to your problem?
 I discovered the exact same issue with my single moto massage today. My neck jets (along with everything else that uses air) in that seat work fine, did yours? I was suspecting, since the neck jets worked, it was the air hose from the valve to the MM may have split or came off.  I have not opened the covers to check this out at all, (it's too cold out there today!) However, it would seem to make sense,  that a single air hose would feed both of the dials that control that seat's MM, then individual hoses would go from each dial to the shoulder/ back ports of the MM? Anyone know if my thinking is correct?
I seldom use the single MM seat, so I may wait till it's warm again to tackle, but would appreciate any guidance.
thank you,
Randy
Share this post
Link to post
Hi, I did find the issue, and it was a simple fix.
I popped off the air adj. valve dials (on top of tub, they just pry off) that went to the problem Moto-Massage and using an air compressor with an air blower end, blew air into each one. Bubbles came out if each air jet except for the problem MM. Assuming it was plugged somehow, I then took the air hose off the MM, and stuck the air valve into the jet, holding a towel to help seal around the air hose. This would reverse the usual air flow, and hopefully clear the line. When I released the air, it took a few seconds, but a piece of fuzzy garbage blew out of the removed air valve on top. So somehow, something got sucked in the air line and plugged that line.
So if you have access to an air compressor, it’s an easy fix.
Hope this helps, Randy
Share this post
Link to post
I took the control knobs off leaving a white plate.  Should that come off too?  Does it pry off or possibly screw off?  I didn’t want to break it.  I have a 2006 Hot Springs Sovereign.
Share this post
Link to post
Hmmm, mine is a 2008, but I would think they should be the same.....it's been a while so I can't remember exactly what it looks like now. However I did find this video that explains it better than I can in words. It may be slightly different than yours, but It verifies you need to remove that actual valve after removing the knob, too.  You should then be able to see an opening in the plastic that runs below each knob. Each opening has several other holes that are actually fittings that have hoses (that you can't see, cuz they are within the shell) that run to the various air jets.  I am not at my home currently that has the tub, or I would check for you. If you still have issues and can wait, I will be back there the end of next week and will investigate. Thanks, Randy
Share this post
Link to post
Video and advice helpful but the thing that helped most was replacing filters.  I had been cleaning them regularly but all good things wear out I guess.  Thanksmuch.  th
Share this post
Link to post
