kpoh
Swim Spa Recommendations
We are looking at 12-14' swim spas and its hard to find many reviews about any of them online.  So far we have looked at the Premium Leisure AQ11 and AQ14, the Tidal Spa EP12, and the Coast Spas Wellness infinity.  We like the seating in the PL AQ14 and Tidal Spa 12 better than the Coast but I am concerned about the warranty and zero reviews on these.  Can anyone help, or recommend other quality swim spas?  In reality I want one with relaxing seats at one end with plenty of jets and a deeper side for the kids to swim around in.
Thanks!
Share this post
Link to post
If swimming is a main goal, I'd suggest the flattened swim jets of the Coast over the round high volume jets of the other two. The stream is wider and easier to stabilize yourself in. Either way it will take some getting used to. The F-1325 by CalSpas is a good unit that we generally show on our floor but I'm not sure if you have a dealer close. Regardless of what you end up buying, I always suggest full foam insulation if it's available and built in ozone is also a good idea. If at all possible, buy because of the dealer as much as for the brand and layout. Even the best product on the market can have issues, having someone local who you can count on to take care of you should be one of your biggest purchasing points. Keep in mind that these things will probably only heat at about 3 degrees per hour so don't expect to swim in 80 degree water at 4:00 and relax in a 102 degree hot tub by 8:00. Good luck to you.
Share this post
Link to post
Hi, I would definitely recommend Splashes, you can see more details on their website. We have it for year and a half and we are satisfied with the quality. We had no issues with the installation and it has provided us with hours of enjoyment :) The only "issue" is that we can't take our kids out of it for hours :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
