Stevie Wonder Posted September 13, 2017 Report Share Posted September 13, 2017 I have a claspa from 08. It's a good sized one. We have had almost zero issues until last year. Heater went out in October, ordered heater and installed sadly after first freeze. Luckily I drained and used rv antifreeze. Only minor damage. Now for today. We had a power supply issue around lunch. Everything in the house with a display was blinking PF. So after looking around noticed the hot tub cover inflated? Went out to check and the heat coming off was unreal. I popped the cover and steam poured out. Display read HH. Could not touch the water. Pulled the access panel and saw the gate valves all deformed and leaking. I pulled the breaker, left the cover open the last 3 hrs. Still can't touch the water. So I'm thinking heater/controller and maybe a pump and all new gate valves. Is this even worth fixing or should I just get a new one. Being 8-9 years old. Also would it have enough residual value to try to go for homeowners ins? If that would even be a covered thing?? Quote Link to comment Share on other sites More sharing options...
Stevie Wonder Posted September 24, 2017 Author Report Share Posted September 24, 2017 No opinions? I was hoping that once cooled down the gates would go back to normal size but they have not. Just constant dripping from every connection. The gate valves look to all need replacing. Is it possible to remove the PVC connection from the flex hose? Quote Link to comment Share on other sites More sharing options...
