Adam F
Watkins classic model f no heat
Adam F    0
95 midel f, no heat. Circ pump flows, turn thermostat dial and I can hear it kick in, wire going to heater gets luke warm, but no heat. Tested continuity at heater and I got 10 ohms (good) so what is the problem?
Share this post
Link to post
Adam F    0
It appears to be a PITA to get at the control box, its in a tight spot and doesnt open up from the outside. Id have to remove it to check. Can I unplug the heater from the box, and use my meter to see if I'm getting 110v at the plug?
Share this post
Link to post
Adam F    0
How do I test the 2 thermistors that are located on the no fault 1500 heater housing?  Can I bypass them somehow to force it to heat up?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
