rdlawler@yahoo.com Posted August 21, 2017 Report Share Posted August 21, 2017 I have a 2016 marquis 322. It runs on high speed for 15 minutes and then shuts down. The manual states it to run on hi for 15 minutes and then followed by low for 15 minutes. The company tells me that the manual is in error nevertheless the recent manual has no change (15 followed by 15). Anyone have a 2016 or 2017 322? How does theirs run? Quote Link to comment Share on other sites More sharing options...
castletonia Posted August 22, 2017 Report Share Posted August 22, 2017 Pretty sure your dealer is correct. I sold Marquis from 2014-2017 and I cannot recall where after running 15 minutes on high it would run 15 minutes on low before shutting down. Unless your spa is either heating or in a filter cycle, it should shut off after running on high for 15 minutes. Quote Link to comment Share on other sites More sharing options...
rdlawler@yahoo.com Posted August 22, 2017 Author Report Share Posted August 22, 2017 But why would the manual say otherwise? I had the same tub from 2000 and it always did the two cycles Quote Link to comment Share on other sites More sharing options...
Markee Posted August 23, 2017 Report Share Posted August 23, 2017 The jets will time out after 15 minutes, but if it needs to heat it will keep running until up to temperature. It will also do an automatic clean up cycle called Smart Clean after you use the hot tub. Generally it will wait for the jets to shut off for 30 minutes before automatically turning back on for a 1 hour SmartClean cycle. Quote Link to comment Share on other sites More sharing options...
