Slycooper91 Posted August 17, 2017 Report Share Posted August 17, 2017 Hi I have a 2000 hotsprings jetsetter model j that I'm attempting to repair. So far I replaced the heater circulation pump which got the hot tub working after 2 or 3 years of sitting for about 5 days after which it started to blow the gfci plug. I ohm'd the heater and it reads 10.8 ohms. When I reset the gfci it starts up Until it hits the heater and trips. With the heater unplugged it operated normally. What could cause the problem in the heater if the resistance is In spec? Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted August 19, 2017 Report Share Posted August 19, 2017 You need to check the heater to ground. One probe in white or black and the other in the ground wire. Should read open. Any resistance and it's bad. Quote Link to comment Share on other sites More sharing options...
