Zogman Posted May 8, 2017 Report Share Posted May 8, 2017 So my father in-laws spa is about 15 years old. It was made by US tooling and Spas. His high current GFCI is bad and I am unable to find him a replacement GFCI. It's a Leviton 8895-E. The Leviton site and everywhere else I search says it's obsolete without a replacement. Since the GFCI is crucial and I'm not comfortable with just putting in a regular GFCI in it, does anyone have any ideas?? As a note, the 8895 has a donut on the back of it for the high current lines to go through them. I have attached a picture. Any thoughts would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted May 10, 2017 Report Share Posted May 10, 2017 http://www.homedepot.com/p/Eaton-60-Amp-4-Circuit-Type-CH-Spa-Panel-with-Self-Test-2P-GFCI-CH60SPAST/206696152?MERCH=REC-_-PIPHorizontal1_rr-_-206184042-_-206696152-_-N Don't screw around with GFCI's. It's your life you're protecting. Saving a few bucks to find a "maybe replacement" for an "obsolete" breaker won't be a great savings to your family while they're looking at you in a casket. Buy new, buy modern and don't cut corners on electrical safety. My two cents, for what it's worth. Dave Quote Link to comment Share on other sites More sharing options...
Zogman Posted May 10, 2017 Author Report Share Posted May 10, 2017 Thanks Dave. I'm definitely not looking to cut corners. That's why I asked what the heck replaced this part. That box is a 60 amp panel. Does that mean I need to buy an additional 120V 20 AMP GFCI to go into it? I'm kinda lost on how this replaces it since it looks like I just end up putting in a regular GFCI breaker. Please take a look at the link below, your thoughts would be appreciated. https://globalcommercialparts.com/hatco-r02-01-221-gfci-switch-retrofit-kit.html Thanks Zoli Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted May 12, 2017 Report Share Posted May 12, 2017 Is your spa a 240VAC spa that's hard-wired, or a 115 VAC that plugs into an outlet? Quote Link to comment Share on other sites More sharing options...
Zogman Posted May 14, 2017 Author Report Share Posted May 14, 2017 Hey Jerry. Thanks for helping on this. The spa is 240v hard wired. It has an older Nu-wave spa controller on it and the gfci on the controller is what is bad. In looking at it, the gfci is a 120v unit but the 220v lines go through the back of the donut on the gfci ad an added precaution. I tried to attach a pic but it's to large it's a Supreme Series controller That being said it looks like Nu-wave make replacement controllers that look very similar and they even have a gfci in the same exact spot. i did a quick web search and can't find a nu-wave web site for tech support. Any thoughts would be appreciated. thanks zoli Quote Link to comment Share on other sites More sharing options...
Jamlank Posted February 15, 2018 Report Share Posted February 15, 2018 Hi Zogman. Did you ever find a solution to this. I have the exact same situation. Older spa. Need that same gfci. Thanks Quote Link to comment Share on other sites More sharing options...
Frank99 Posted February 17, 2018 Report Share Posted February 17, 2018 I'm not an electrician, so take this as the advice of a random person on the internet. The solution is to throw away the old GFCI, and install a GFCI in the circuit breaker panel of the same amperage as the current circuit breaker. It'll cost you $50-$100, but it's the modern and safest approach. If "replace circuit breaker" is not one of your strengths, call an electrician to do it for you - maybe another $50-$100. You really don't want to have a spa without it being protected by a good GFCI. Jersey Hot Tub's suggested solution is similar - it's a new box that you'd mount near the spa. Run the wires from the main breaker panel into the new box (with a built-in GFCI), run wires out of the new box to the spa, and you're good to go. Quote Link to comment Share on other sites More sharing options...
Cusser Posted February 17, 2018 Report Share Posted February 17, 2018 Ha !!! My 1988 CalSpa did not come new with a GFCI for the tub, just one for the light !!! Mine's 40-amp, 240 VAC hard-wired, done by professional electricians who also ran the 240 VAC wires through my attic. I read about GFCI for spas in Popular Mechanics magazine a few years later, and added my own 40-amp GFCI for the tub/heater/pump etc. Well, at least I have a shut-off close now, my GFCI is inside my redwood cabinet. My Cutler-Hammer circuit breaker box is like 75 feet away, on the other side of the backyard wall. Quote Link to comment Share on other sites More sharing options...
rowoco Posted June 25, 2018 Report Share Posted June 25, 2018 i have the same situation.if i already have a 50 amp gfci external breaker can this just be taken out and bypassed Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted June 25, 2018 Report Share Posted June 25, 2018 I'd recommend you contact the spa manufacturer and get a written response telling you if your 50 amp GFCI external breaker is a replacement for the existing one. The reason I say that is because the tub was designed for safety "as built." If it's UL Listed, it meets a specific build requirement that you shouldn't be modifying. If you modify things and something bad happens, your liability is exponential. Worst case: there's something in the design you're unaware of and you remove the GFCI. Your family uses the tub and while someone is getting out and one leg's in the water and the other wet foot is touching the ground, you learn that your modification was a mistake and a loved one gets electrocuted. A law enforcement or insurance inspection finds that you removed the GFCI, and even though a stranger on the internet said it was safe to do, you find yourself getting arrested for manslaughter as you're driving home from your family's funeral. If you have to ask "is it safe," then you shouldn't be doing it. Just a little friendly advice from a risk-averse hot tub repair guy. Dave Quote Link to comment Share on other sites More sharing options...
alaska_guy Posted July 9, 2018 Report Share Posted July 9, 2018 Usually most tubs require a 50amp double pull breaker from your existing inside panel. 6 gauge wire is usually used to feed this breaker and wired to run to your hot tub. This then feeds a disconnect box on the outside of your house. Depending how your tub runs, you typically have a 30amp 240v GFCI breaker inside and then usually a 20amp GFCI breaker for the 120v side. The disconnect needs to be 5' min away from the closest water part of the tub for safety and to meet code. The easiest method, but not to code would be below.... It sounds like you already have a 240v direct line and were using a plug to go into a 120v GFCI. What I would suggest is buying a spa disconnect box, wire your 240v into it with the correct sized breaker. If the cable is not long enough you could use a metal box and conduit to extend the wires to the location needed. I would then suggest plugging your 120v side of your tub into a regular 120v GFCI if you already have one close by and that's how your tub is setup. This would keep you safe. I used to be a commercial electrician before switching trades a few years back. The second method saves you about $50 and some time. The first method is the ideal method and meets code. Quote Link to comment Share on other sites More sharing options...
Cusser Posted July 10, 2018 Report Share Posted July 10, 2018 On 2/17/2018 at 4:35 PM, Cusser said: Ha !!! My 1988 CalSpa did not come new with a GFCI for the tub, just one for the light !!! Mine's 40-amp, 240 VAC hard-wired, done by professional electricians who also ran the 240 VAC wires through my attic. I read about GFCI for spas in Popular Mechanics magazine a few years later, and added my own 40-amp GFCI for the tub/heater/pump etc. Well, at least I have a shut-off close now, my GFCI is inside my redwood cabinet. My Cutler-Hammer circuit breaker box is like 75 feet away, on the other side of the backyard wall. Quote Link to comment Share on other sites More sharing options...
Stuffy8 Posted December 15, 2019 Report Share Posted December 15, 2019 Hi Zogoman, I am now going through the same problem. I have the exact same unit with the donut hole in the back that no one in all the 6 places that I went to every saw that type of outlet. Did you ever figure out what to do or have someone do it for you? Thank you Paul Quote Link to comment Share on other sites More sharing options...
torque2 Posted September 6, 2022 Report Share Posted September 6, 2022 I don't know if anyone still needs a Leviton 8895-E 80amp with the donut in back, but I have some brand new black ones still in the box. Just let me know and I can ship them for $50.00 each including shipping. Quote Link to comment Share on other sites More sharing options...
CrestlineCalSpa Posted October 1, 2022 Report Share Posted October 1, 2022 Anyone figure out what to do without the Leviton 8895 gfci which is now discontinued? Has anyone tried repairing / rebuilding the existing gfci? When I manually press the top/red/on button on the gfci, it works. Makes me thing the spring is just worn out? I contacted torque2 but haven’t heard back. Anyone ordered from him?? thanks Quote Link to comment Share on other sites More sharing options...
CrestlineCalSpa Posted October 8, 2022 Report Share Posted October 8, 2022 I ordered a replacement from torque2 for $50. It arrived promptly. Thanks! Quick question though… my OG gfci is the Leviton 8895 and the one torque2 shipped is the Leviton 8886-e. They are very similar, BUT the donut is smaller and the way the two white wires and two red wires attach to the gfci is different… anyways I’m wondering if anyone knows a reason why the 8895-e wouldnt work to replace the 8895. Seems easy enough to make minor modifications to accommodate the few physical differences in the two. I couldn’t find the 8895 anywhere and am happy that I was able to find this 8895-e. the OG 8895 lasted 24 years btw! I was able to troubleshoot that the gfci had failed by manually pressing the red button on the gfci and the spa would turn on, fire up the jets, etc.. I plan on trying to repair the OG 24 year old Leviton 8895 gfci. Seems like it’s just a physical spring or catch that has failed. Anyone have any experience / tips on repairing a gfci? thanks Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 9, 2022 Report Share Posted October 9, 2022 On 10/8/2022 at 10:22 AM, CrestlineCalSpa said: I’m wondering if anyone knows a reason why the 8895-e wouldnt work to As long as the amp rating is the same it should be fine. On 10/8/2022 at 10:22 AM, CrestlineCalSpa said: Anyone have any experience / tips on repairing a gfci? No experience, just advice: DON'T! A gfci is a very sensitive (.005 amp) safety device designed specifically to save lives. It serves no other purpose. I strongly recommend that you DO NOT attempt to repair or alter any electrical safety device, especially a gfci. The only result for failure is electrocution. BTW, current code requires the use of a gfci breaker for a spa, installed in your panel or disconnect (also now required). If you have it on a gfci breaker you can eliminate the one in the pack. You do not need 2. 1 Quote Link to comment Share on other sites More sharing options...
