f16_fixr 0 Posted April 16, 2017 Report Share Posted April 16, 2017 New to this forum. I have a 2013 Hot Spring Limelight series hot tub which I have had zero issues with until recently. I noticed the display letters/numbers started flickering and going off and on intermittently. Luckily, I was able to turn off the pumps and lights before the control head totally died! I removed the panel from the tub body and disassembled it, only to find that the silicon pad (3 buttons) on the left side which controls the jets and "mode up" and "mode down" settings was cracked around the base, allowing water to penetrate into the head and drip right onto the circuit board. My thoughts are this is a very poor design and if there was even a cover over the circuit board to divert water away from dripping directly onto the board, this never would have happened. Also, any parts searches are showing this control head as a complete assembly when it is easily able to be disassembled by removing a few screws. Does anyone know of a place where I can order the separate components that I need rather than having to shell out $320. plus shipping for a new unit? Any help would be greatly appreciated. Quote Link to post Share on other sites
Jersey Hot Tub Repair 2 Posted April 17, 2017 Report Share Posted April 17, 2017 Maybe these folks can help you: http://www.a1spacontrol.com/ Quote Link to post Share on other sites
f16_fixr 0 Posted April 18, 2017 Author Report Share Posted April 18, 2017 Thanks much for your input! Quote Link to post Share on other sites
Jersey Hot Tub Repair 2 Posted April 20, 2017 Report Share Posted April 20, 2017 Of course, if water is leaking through the overlay, repairing the circuit board isn't enough - you need a new overlay or it's just going to get wet again. Quote Link to post Share on other sites
f16_fixr 0 Posted April 20, 2017 Author Report Share Posted April 20, 2017 Right you are! They told me they cannot order just the overlay as a separate item. Ended up buying the entire control assembly from my local dealer. They matched a price I found on the web and saved me the shipping charges, which was pretty cool. Everything is back together and working fine again! :-) Quote Link to post Share on other sites
