louisvillediddy Posted December 15, 2016 Report Share Posted December 15, 2016 (edited) Hello all, looking for help getting my 2006 H2X Master Spa working. I'm new to having a spa tub, but a pretty crafty guy. Here's the situation: Moved the tub from Indy to Louisville, KY. Got it placed and electric hooked up. Filled it and for the first week nothing came on, finally realized I had the breaker terminated wrong. Got it working today,(it's 30 degrees here), and I'm trying to make sure nothing's frozen and/or broken. Looks like all the pipes are ok although I have a little leakage from one of the shut off valves from pump 2 but it seems to be running fine and circulating water through the standup jets. My screen is throwing a DR code, I cycled through 3 times and now it's showing me a DY Code. The manual says the DY code is Inadequate water detected in heater, Pump 1. Pump 2 seems to be cycling water through, Pump 1 doesn't even spin, and when you press the heat button it tries, but then clicks off (I can hear the click in the control unit)I'm wondering if their's air in the line or if there is ice in the line preventing water to flow into the heating element. I'm also wondering if I need to prime pump 1? Do I need to by a new pump? Additional info: Filters were cleaned, I haven't put any chemicals in yet, (should I?) I have pics, but it wont let me upload. Pump 1 is a Balboa 56FR, 4.5HP, 2 speed, 240, 10amp, model DJAYGB-3155MB, I've found one online for $455. I haven't even looked or tried the swimming cycles and pumps yet, anything i need to look out for here? Any help would be awesome, I'd like to get it running and heating asap or I will need to drain it. Edited December 15, 2016 by louisvillediddy made it more clear Quote Link to comment Share on other sites More sharing options...
louisvillediddy Posted December 15, 2016 Author Report Share Posted December 15, 2016 Update. I did prime the pumps to try and get any air out, but it seems like there was plenty of water coming out, and I didn't hear the hiss I was expecting from a possible air block. I also checked the shaft of pump one and it wont turn. It has a little corrosion on it, but was assured by the previous owner that it worked up until the day I got it. I'm wondering if I need to replace the motor? Do I take it out and check it by hand? I can hear in PR mode it try to click on but it doesn't turn.... I found this, would need the 56FR version... http://bathandspaparts.com/djaygb-3155mb.aspx Quote Link to comment Share on other sites More sharing options...
