RobBritinCali Posted November 28, 2016 Report Share Posted November 28, 2016 I have an older Sundance spa that came with my vacation home. When visiting this weekend, I found an "FL O" error on the tub and it would not heat. (All other functions, blowers, lights etc work). I took out the circulation pump, it appeared to be stuck and then it freed up. I refitted it but it still did not run. I also tested the pressure sensor and tripped it into closing which started the heat but still no water flow (Stopped that after 5 seconds to avoid any burn-out/over heating etc). I'm pretty certain the circulation pump needs replacing, but I want to check it first but am not sure if it constantly runs or not - If it does then I know I should expect a constant voltage to it whilst the spa is on. Thus, my question is: Should the circulation pump be constantly running even when the spa is not heating? Any advice would be great, thanks Quote Link to comment Share on other sites More sharing options...
dg98adams Posted November 28, 2016 Report Share Posted November 28, 2016 I have an older Sundance (Cameo). I think mine heated when the filtering was running (220v).... the filtering was controlled by a mechanical timer switch that was user controlled for "how & when" in a 24 hour period... The timer switch went bad once, as I had replaced it. On the pump that you "freed up", is there rust between the pump and the motor on the shaft? You may have a leak there at the seal that caused the motor/shaft/bearings to wear. Also, have you checked the filter? when they clog up they can inhibit flow. Quote Link to comment Share on other sites More sharing options...
RobBritinCali Posted November 28, 2016 Author Report Share Posted November 28, 2016 Thanks for your response. The filter is new and I checked the flow lines through from that, though the heater and into the spa and there are no blockages so I've eliminated that as the issue. I couldn't see any mechanical timer on the board either and the circuit diagram (attached) doesn't appear to snow the presence of one either. As for the pump- it wasn't rusty but the back of the impellor and around the shaft had lots of mineral deposits on them (possibly Chlorine etc) which game me the impression it had leaked possibly. I couldn't see any other signs of damage on it though Thanks spa circ dia_1.pdf Quote Link to comment Share on other sites More sharing options...
