Crowbait Posted November 21, 2016 Report Share Posted November 21, 2016 Good Morning, I want to first say thanks for all the great info. I acquired a used tub, and you guys helped me turn this tub into very a positive experience by sharing all of your knowledge and experience. So this is a simple question. I accidentally put too much Gentle Spa into my tub after decontamination and refill. I should have put 1.5 cups, based on my 450 gal tub, but put 2 cups instead. Is there any harm in leaving this, or should I do a partial drain and refill? Thanks! Byl Quote Link to comment Share on other sites More sharing options...
chem geek Posted November 29, 2016 Report Share Posted November 29, 2016 It's not a problem. You can rectify it the next time you change the water. Quote Link to comment Share on other sites More sharing options...
Rickroebuck Posted March 8, 2017 Report Share Posted March 8, 2017 You must try to use 1.5 cups or less than that to make the water's quality better. And never forget to change the water as quickly as possible after use. Quote Link to comment Share on other sites More sharing options...
